P1105 code is not going away
I've replaced map sensor, code still shows. What's the issue?
좋은 질문입니까?
좋은 질문입니까?
@smooch a failed MAP/Baro Switch solenoid can give you the same code. Check for more reasons for code P1105 on here If that solenoid does not open then your sensor does not get a vacuum and will read barometric pressure which will trigger this code. Check the solenoid by unplugging the vacuum hose on the sensor and attach a vacuum gauge to that. Start your car and within seconds your gauge should read a vacuum. If there is no vacuum then it is most likely that your solenoid has failed. Of course this will only work if your vacuum hoses are not cracked etc.
이 답변이 도움이 되었나요?
지난 24시간: 2
지난 7일: 9
지난 30일: 38
전체 시간: 5,032
