주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus X555L은 2015년 5월에 출시된 저가형 노트북입니다. 이 안내서에 묘사된 모델은 일반 소비자가 구매하기 적합하도록 설계된 Intel Core i3 프로세서 탑재 노트북인 X555LA-SI305041입니다. 유사 모델 번호: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN 및 X555LP
Factory Reset Gone Wrong
My laptop was being very slow, to the point where i simply couldn't open two applications at once. I decided to factory Reset the whole thing, i've done this previously on other laptops so i didn't see the problem. After the reset i closed down the laptop and left it for a few weeks. I tried to go on the laptop in question yesterday and it is not accepting the password (I haven't changed the password and i am certain of what it is). The password hint has also changed, it is missing letters and words. I have tried to create a password reset disk using another computer and this has still not worked, it throws up errors when i try to reset my password. I am totally lost on what to do. The F8 and F9 button seem not to work or respond and I feel like i have tried everything obvious. There is no way of getting into the laptop but it looks totally fine.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Hi ,
Since you've already done a reset once, try doing it again.
You've got nothing to lose except a bit more time.
이 답변이 도움이 되었나요?
점수 2
댓글 5개:
I can't get onto the system to do another reset, It was my first thought but theres no way how. Any ideas?
Try using a Win 10 recovery USB and boot from it to reset the laptop.
The USB recovery drive can be created from any known working Win 10 PC. Go to Control panel > recovery > Create USB recovery drive
You'll need 8GB flashdrive and 40-60 minutes of time.
Don't forget to enable USB legacy or CSM in BIOS settings of laptop and alter boot option to USB drive as 1st option.
How do I do the last part?
"Don't forget to enable USB legacy or CSM in BIOS settings of laptop and alter boot option to USB drive as 1st option."
The F9 key won't work at all.
Hi,
For your laptop press F2 during POST. i.e after laptop starts and before Windows boots to enter BIOS setup.
p.66 of the User Guide
You have to get the timing right. If too early the PC will beep at you and stop. Let go the F2 wait 0.5 sec and press F2 again. Another way is to continually keep tapping F2 until you see BIOS screen.
If pressing F2 too late and Windows starts to boot up, press and hold Power button until laptop shuts down and then start again.
You can also change boot order in BIOS
댓글 달기
Dose the machine boot into windows, in other words is it a windows password ? or is it like a Bios password ?
If its running windows 10 it may have switched to your microsoft account. try the password of that.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
I've tried the windows password and it won't accept this.
can you take a photo of the password screen your seeing and upload it here ?
댓글 달기
답변을 추가하세요
sally wall 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 10
전체 시간: 3,793
