주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Surface Pro 4의 후속 모델로 2017년 6월에 출시되었습니다. Microsoft Surface Pro 12.3"로도 알려져 있습니다. 모델 번호: FJT-00001.
Heat Gun/Blower for Screen Replacement
I am looking at purchasing a heat/gun blower to replace my Surface pro 5 screen (warm the adhesive to weaken it)....as well as for other electronics.
I have come across 3-in-1 Function Heat Blower and Soldering Iron (see link below), which I thought could be helpful with other projects also.
https://www.jaycar.co.nz/3-in-1-function...
Has anyone had any experience using this type of "heat blower"? First thought is it may be difficult to control the temperature...although it does have a flame adjustment setting.
Thanks in advance for your help.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
Hi @dgmossman ,
You may wish to take note of the warning at Step.1 in the ifixit Microsoft Surface Pro 5 스크린 교체 guide.
Just a thought.
Go for an iopener, otherwise it's too easy to damage the surface.
댓글 달기
답변 2개
선택된 해법
I think the soldering gun you picked will be to narrow an area and far to hot to do the job well. I believe you chances or success on this repair would be much greater with a standard heat gun:
Heat Gun
Loosen adhesive or reflow solder with this 1500W heat gun. Low setting reaches 570 degrees F (300 degrees C). High setting reaches 1112 degrees F (600 degrees C). 이미지
제품
Heat Gun
$29.99
이 답변이 도움이 되었나요?
점수 3
댓글 달기
I would use the iOpener or a heatmat.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Daniel Mossman 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 4
지난 30일: 20
전체 시간: 1,684
