loud buzz when you turn it on
awr1-1w. When I turn it on there is a very short, loud buzz from speakers. Then no audio output. display works fine and shows choice of station and time when turned off. keypad on top functions perfectly just no audio after initial loud buzz.
좋은 질문입니까?
댓글 1개
Hi @sierra26 ,
Try connecting an external audio source via the aux input to check if the output audio is OK or not. Press the Aux key to select input.
if it is OK then at least the amp section of the radio is OK.
Have you checked the antenna connections?
jayeff 의
