주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년 8월 출시. 3.0인치 LCD 모니터를 탑재한 1,600만 화소의 포인트 앤 슛 카메라.
Is my camera broken?
When I turn on my camera, the lens goes out a little bit, the green light on the back of the camera flashes once, and the back screen doesn't turn on at all. When I press the power button, the lens goes back and the green light flashes twice. I haven't turned my camera on for about half of a week and bring it to school everyday. I make sure nobody goes into my bag and have been keeping it completely secured. Anything?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Hi @x_trash_x
It seems as though there may be a lens problem, which unfortunately, is fairly common with a lot of cameras.
The problems usually are caused by:
Sand or grit interfering with the lens extension mechanism.
The camera has been dropped with the lens extended.
The camera has been powered on, but the lens had been blocked preventing its extension.
The camera was packed in too tight, compressing the lens.
It can even happen with regular use where nothing was done wrong.
Try the following:
Blow compressed air in the gaps around the lens barrels to hopefully blow out any sand or grit that may be in there jamming the lens mechanism.
If you do notice anything around the barrels and it won't dislodge using compressed air (or even a vacuum cleaner) try "gently" tapping around the lens barrels with a pen etc., to try to dislodge any particles that may be jamming the lens barrel mechanism. At the same time turn the camera on and off as you're doing this.
There are a few more extreme methods but they could potentially cause more damage to the camera lens mechanism and still not fix it.
You could try replacing the lens mechanism, (here is a link to the ifixit Canon PowerShot SX520 HS 렌즈 교체 guide) however searching online indicates that you can get a good used working SX520 HS for less than the cost of the replacement part.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Liam Wahl 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 37
전체 시간: 1,724
