주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Why does phone gong instead of ring?
I have an Alcatel One Touch Idol 3. Occasionally, instead of ringing like it should (using the ringtone I selected as default) the phone just gongs slowly. It particularly happens when my son calls (I have no idea why). The problem is that the gonging sound is quite low in volume, and I almost always hear it too late to answer in time. Does anyone else have this problem, and if so, how can I fix it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Hi Joe,
Has the gonging ever happened when someone other than your son called?
댓글 달기
답변 2개
If the ring tone only makes that sound when your son calls and with no one else , then it sounds like you or your son set the ring tone to that sound. You can set different ring tones to each individual contact. All you have to do is go to your son's contact, click edit, scroll down to were it shows ringtone, and then change it or set it back to default.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I already checked that. The ringtone was set to default.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Joe Perrone 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 27
전체 시간: 299
