주요 콘텐츠로 건너뛰기
Apple의 PowerBook 노트북 라인은 전문가와 파워 유저를 위해 만들었습니다. PowerBook 라인은 PowerBook 100, Duo, 500 및 5300 Series; PowerBook 1400, 2400, 3400; PowerBook G3, G4 Titanium 및 G4 Aluminum으로 구성됩니다.
20 질문 전체 보기
질문 마감됨
Fans force air when turning on PBG4
Watching the Audi Channel one night the PB screen went black (that was before it stuttering on the internet connection).
When turning back on, the fans just keep blowing air and there is no display. Screen is black. No beeps.
This is 15" PBG4 - had for a bout 4yrs. Could the screen inverter have gone or is this a logic board issue.
Help appreciated.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Check the RAM of the computer try re-seating it, and see if that works. If not, you may have a much more serious problem, you may want to look into putting a shim on the CPU, and GPU, if that solves the problem, tell me, and i'll go into more detail on a permenant repair procedure
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Not sure I understand what you mean by "shim" - can you explain?
A shim is a non-conducting spacer between the case and the chip to force it into contact with the logic board.
댓글 달기
It's not the inverter, if that failed it would still boot normally, just with a black screen. As it is ramping the fans up that is the logic board entering CPU protection as it isn't booting, but as the screen is staying black, would say it is due to a failure on the logic board.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I'm guessing it's the logic board, but want to try some things first. I do get an intermittent chime from the PB, but then it goes silent and just blows out air from the fans
댓글 달기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 962
