Stops at spin cycle with UL
what do i need to fix if it stops on spin cycle with UL. its spins in one direction for couple seconds then stops n starts to spin in opposite direction...it does this back n forth over and over but never goes into spin cycle
좋은 질문 입니까?
댓글 4개
My washer does that Ul code at the final spin the entire bucket moves uncontrollable the the ul codes appears
Julie Cruz 의
@Julie Cruz
What is the model number of the washer?
Bucket moving about might be a problem with the suspension rods.
knowing the full model number will help to find the correct part if they are faulty/broken etc.
jayeff 의
Maytagz quiet series bravos 300
Lee Hart 의
@Lee Hart
if it is the suspension rods that are the problem, knowing the model number will ensure that the correct parts are listed in an answer.
jayeff 의
