주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Pavilion dv7-3065dx는 와이드스크린 휴대용 엔터테인먼트 노트북입니다.
caps lock blinking continuously WiFi light amber
My computer won’t boot to the start up screen or even start up after a hard boot. The minute it is turned on the caps lock blinks continuously and the WiFi light is amber. Acts like it is stuck. I have tried a hard boot, holding the windows key and v or b and nothing works.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개
Hi @momdad_4
Had you tried removing all the RAM from the laptop?
Try booting up with one stick at a time.
It worked for me!!! tks!!! so now it is working with just one stick. Should i replace the other one right?
Well try the one you think is defective as the single stick, just in case it wasn't seated properly to start with.
댓글 달기
답변 2개
선택된 해법
Hi @momdad_4 ,
Check if there is a pattern to the blinks, rather than it being a continuous blink.
If there is or even if you're not sure, then here is a link to the LED error codes for HP notebooks.
Scroll to BIOS light flashing error codes for computers released between 2011 and January 2015 and click on the + symbol checkbox to expand the list.
Check if any of the "codes" are relevant.
Another thing to try is a power refresh.
Disconnect the charger from the laptop, (if connected), then remove the battery from the laptop, (using the ifixit HP Pavilion dv7-3065dx 배터리 교체 guide if necessary). Then press and hold the Power button on the laptop for 30 seconds to drain any residual power from the laptop.
Reconnect the charger to the laptop, (leave the battery out at this stage). Switch on the charger and turn on the laptop.
If it starts OK, allow it to boot all the way to the Windows desktop. Allow the HDD activity to settle down then shutdown the laptop in the normal manner.
Once it has shutdown completely, switch off and disconnect the charger, reinsert the battery, reconnect the charger and switch it on.
Turn on the laptop. If it starts, allow it to boot all the way to the Windows desktop. Once there, check the charge status of the battery. If it is charging, allow it to fully charge before disconnecting the charger.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
If those mentioned doesn't work, check if you get power to the usb after booting. If you get no power to usb or your hard drive is not running then you have to replace the motherboard. Motherboard can be fixed too but you have to understand the schematics if no idea just buy the motherboard and I guess it's not that expensive when you're the one installing it the only thing that it will become expensive is when you send it to a repair shop. There are some guidelines and videos in youtube on how to replace those.
댓글 달기
If trying to recover the BIOS doesn't work then it's more than likely you have the classic "HP Motherboard Failure" that plagued these laptops, whereby the CPU or GPU would just completely die.
Here's a video to someone else having the exact same issue (note that overheating caused this one, and HP DV's are well known for overheating).
https://www.youtube.com/watch?v=Onrd8Liu...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Donna hobbs 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 24
전체 시간: 38,584
