주요 콘텐츠로 건너뛰기
The QiCycle Folding Electric Bike is Xiaomi’s first foray into the world of e-bikes. It has a 250W high-speed motor powered by Panasonic 18650 lithium batteries. The Shimano Nexus 3-speed gear hub in combination with the torque measurement sensor gives you up to 45km bike power on a single charge. It also has a trip computer can connect to your smartphones via their special app and is–of course–foldable.
54 질문 전체 보기
Watt-meter display jumps and motor stops
Hi Guys,
The past 2-3 weeks I’m experiencing a problem with the electric bike.
The meter of Watts in the display has a lots of variation and while it might be at one moment 140 Watts, it can change to 200 Watts after a second without any reason (cycling with steady pace).
This results in stopping the motor even if I am under the limit of 25km/hr (kind of blocking it so it doesn’t give boost) as it is probably limited to going to a certain amount of max Watts.
The solution for the motor to keep giving boost is to stop the bike and start again from 0 Watts.
Any ideas on this/have you encountered something like this before? I’m trying to figure out what might cause the problem. It all started after I fell once with the bike.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 1개:
hello i think i have the same pb, but switching off/on the bike don't solve the pb at any time, it's random...
I didn't fall with my bike, but i have cycled under rain, and in mud.
I think it's the speed sensor, but not sure
Xiaomi MiJia QiCycle Folding Electric Bike Teardown
Did you find an issue ?
댓글 달기
답변 1개
Yo también tengo un problema parecido.
A veces no entra la asistencia eléctrica o lo hace de una manera “a saltos”. El indicador de speed da valores irreales.
Si aprieto el cable que llega al display en el manillar el problema se arregla temporalmente.
Creo que tendré que desmontar y revisar alguna soldadura o similar.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
bill depo 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 9
전체 시간: 485
