주요 콘텐츠로 건너뛰기
Repair manuals and support for laptops manufactured by LG.
20 질문 전체 보기
Why is my laptop display split into 3 sections?
My laptop screen split into 3 sections, the right section appears to the left and the left appears to the right, the center remains in the center but keyed out!
This is a picture taken from my laptop
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 12개
Hi @ejdr ,
Try starting the laptop in safe mode and see if the problem is still there.
If it works OK then perhaps it is a driver issue.
Stupid thought but can you "drag" (click and hold while moving) the right side of the screen back to its' proper position on the left?
No it cant move
But sometimes it goes back to normal. Is it possible that its the display assembly?
Var der nogen løsning? for jeg har samme problem.
Hi.My laptop is doing the same too,It's splitting into four sections with a poor quality and a black line crossed between the 2 sides of right and 2 sides of left
댓글 7개 더보기
댓글 달기
답변 2개
선택된 해법
@ejdr it will help if you let us know the exact model of your laptop. Also, even so your description is good, it might help if you post some images of t\what your screen shows. Use this guide for that. 기존 질문에 이미지 추가하기 It will allow us to see what you see. Connect an external monitor to your laptop and see if that displays right. If it does then you probably have an issue with the driver board of your panel. This would require a display replacement (y first suspicion). If it doesn't display properly it could be a GPU issue (motherboard) or a driver issue. Depending on your OS you may consider a driver update for your video card (GPU)
이 답변이 도움이 되었나요?
점수 2
댓글 14개:
When I connect it to a monitor it shows good but in my laptop it splits in 3 sections
Okay, sounds like a bad LCD. You will see there there is a circuit board that is directly connected to your LCD and it is really not replaceable. It is on that board that you have a component failure.
@oldturkey03 what is the possible solution for this?
can I fix it?
Only repair for that is the replacement of the display
댓글 9개 더보기
댓글 달기
I still have an old Toshiba laptop that I don't use much anymore that was having the exact same problem. I plugged in a VGA cord to a projector and both screens are working correctly after that. I also freed up the right hinge that had come disconnected from the base by breaking some plastic away from it. There is a wire that goes through there, maybe it was kinked or half broke because the hinge isn't in the right spot. I did both of these things at the same time, so I don't know which one fixed it, but I suspect it was plugging in the VGA cord to an external video display.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Elvin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 24
전체 시간: 7,682
