주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Stream 7은 Hewlett-Packard에서 제작한 소형 다목적 태블릿으로 2014년 9월에 출시되었습니다.
Why dosent it charge?
I plug it in but it wont charge before it ran out of battery it said when plugged in, plugged in,not charging
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Hi @mosedc ,
Have you tested that the output voltage of the charger is correct, i.e. 5V DC?
Have you tried a different compatible charger?
Have you tried a different compatible charger cable?
What have you tried?
의 공유
Yes everything you said I tried but didn't work.So my brother told me it was the charging port. How would you fix that?
의 공유
댓글 달기
답변 1개
선택된 해법
Hi @mosedc ,
If the charging port (micro USB) was the problem, as it is mounted on the systemboard, you would have to remove the systemboard from the tablet to gain access to the connector so that it either can be replaced if it is faulty (have you visually inspected it with a strong light and magnifying glass to ensure that all the pins (5) are there and that they are all straight and parallel with each other?) or repaired if it is loose from the board for example.
If it is either faulty or loose then you will need SMD (surface mounted device) soldering skills and tools to effect the repair.
Here is a link to the service manual for the tablet. Scroll towards the bottom of p.22 to view the necessary pre-requisite steps and then the procedure to remove the systemboard.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thank you this should help.
의 공유
댓글 달기
답변을 추가하세요
Isaac 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 37
전체 시간: 1,668
