주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Skullcandy Hesh 2는 Skullcandy에서 판매하는 블루투스 무선 오버이어 헤드폰입니다. Skullcandy Hesh 2 모델은 모델 번호 S6HBGY-3xx로 식별할 수 있습니다.
No sound in one speaker
The sound in one of my headphone's speakers is rather faint and sometimes completely absent. I think it might be a internal wiring issue or a faulty speaker. Is there any way I might be able to repair or replace the speaker myself?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 1개
가장 유용한 답변
@rhatten5 you need to check the wiring to the speaker that is not working properly. Depending on which side, it may be the crossover cable or the wiring right on the speaker. Yes you can replace it but you need to find a replacement which is not always easy. At this point I would check the wiring first. Post some images of what your speakers etc. Look like so we can see what you see. 기존 질문에 이미지 추가하기
Check this video to get to your speakers etc.
Use a multimeter and check to see if there is continuity from the plug/board to your speaker. If not then it is the crossover cable. If there is then the issue is with/on the speaker.
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
when i connect my hesh 2 headset on aux cable i get sound on both ears, but when i connect on bluetooth i get sound only on the left ear.. what is the issue.. plz help fixit
의
I have the same issue.
의
I also have this same issue with my Skullcandy hesh2
의
I too :/ help please
의
댓글 달기
답변을 추가하세요
Ryan Hatten 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 21
전체 시간: 4,236
