주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
32인치 1080P LG 32CS560 LCD TV에 대한 문제해결 및 수리 정보.
Only sound is playing?
When I switch on my tv the sound is playing perfectly however there is no picture coming on the screen. I have tried switching it on and off.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Majid Abdul  if your TV is a LG 32CS560 then you want to go ahead and do a basic troubleshooting forst. You will need to remove the back of your TV and check the boards for obvious damage like burned, chared components or domed, leaky capacitors. Pay particular attention to your power board and the main board. Start with the flowchart
이미지
Test the output of the power board to the backlight LED’s, check the connection between power board and main board, and check the fuse on your T-con board for continuity as well as power. Let us know what you get.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Please verify the model number of the set. Also, use a flashlight at an angle toward the screen. Do you see the expected picture there? If so, then the problem is that the back light has failed. This can be due to a number of different problems. The model number will help to narrow down the possibilities. Also, please post a few photos of the board inside the set. This will help to guide you through the next steps.
Dan
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Majid Abdul 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 18
전체 시간: 372
