주요 콘텐츠로 건너뛰기
Huawei’s first smartphone with the new Kirin 970 chip. Released November 2017.
17 질문 전체 보기
My phone fell in water
My phone fell in water when im taking a shower. the speaker doesnt work properly. what should i do about it. it sounds cracky
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Clean every connection with a soft toothbrush. As well clean the logic board; use a 99% isopropyl alcohol for all cleaning. Now is the time to start drying out the phone. Set the screen in a desiccant or silica gel leave it in for several days moving it from time to time to get the max effect from the desiccant. Use a blow dryer on a low heat setting to dry the rest of the phone. Only use a hair dryer once you have cleaned the phone completely with the alcohol. Do not attempt to dry the phone if it’s still wet with water with the blow dryer as this only spreads the water. Replace the battery with a new one considers the old ones done. Clean again with isopropyl alcohol let dry and when you think everything is clean and dry reassemble the phone (make sure to clean the contacts on the screen after removing from the desiccant). Once you've reassembled the phone it’s time to power it on. Hold your breath and hope for the best
Huawei Mate 10 Pro Teardown
Replacement speakers can be found here
Hope this helps
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
CharlieGraal Studio 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 11
전체 시간: 3,571
