주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Xperia Z4(유럽에서는 Sony Xperia Z3+로 알려짐). 1.5GHz 프로세서와 3GB RAM, 2070만 화소 후면 카메라를 탑재한 5.20인치 1080x1920 디스플레이 스마트폰. 2014년에 출시되었습니다.
Not charging after replacing battery
Hi, i just received a new battery for my Xperia Z3+ Dual (LIS1579ERPC).
I replaced it and it's not charging anymore. Conector seems to work because it makes the sound when connected and PC recognizes it but battery icon does not change to charging status and under batter menu it says "not charging".
Tried with USB and original charger. Both with the same result.
New battery is on 20% charge. I didn't do what the note inside the package says to drain it to 10% and charge it to 100% uninterrupted because of the problem explained above.
I tried putting back the old battery and it's charging OK. I don't have another phone to try the new battery.
What can i do?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
It's a faulty battery. Try contacting the supplier / seller you got it from for a replacement.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thanks, i bought it from iFixit and used a forwarder so sending it back for a replacement is not an option.
댓글 달기
답변을 추가하세요
Andres Maidana 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 8
전체 시간: 380
