주요 콘텐츠로 건너뛰기
The Gateway NV52 was released in 2008. It is similar to the MS2274 and NV5207u models.
13 질문 전체 보기
Why is my laptop turn on but not the screen?
at first its wont turn on at all, I opened it, put it back together, now its turn on but not the screen, and once the screen was getting very hot, I have turn it off and power back on again, and the screen still not come on
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
connect your system to external display if its working there must be a fault with display, will reply once you execute the step
댓글 달기
답변 1개
If the fan is spinning when you switch on the laptop and no display this could be a problem with the memory. Try taking it out and putting it back and also if you have 2 memory cards try with one. Try connecting to a monitor. If it works on a monitor the problem is with the inverter or LCD cable.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
If it does not work with a monitor what could be the problem? fix?
댓글 달기
답변을 추가하세요
minh thien 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 2
전체 시간: 501
