주요 콘텐츠로 건너뛰기
The Logitech Dual Action is a USB, PC controller for gaming. Model number: G-UF13A.
16 질문 전체 보기
Logitech Gamepad F310 connects/disconnects
Hi guys, I have this Gamepad or Joystick which doesn't work properly anymore. At first as I connected it to the PC told me that this last couldn't recognize the device so I started to teardown the gamepad thinking that the cable had problems. After desolder and resolder the wires to the PCB I connected it and now the controller shows a kind of loss of power two seconds after being plugged. I measured it with a multimeter trying the vary combinations pointing it to make contact with the pins inside the USB socket and the other end of the cable, of course with the all wires exposed, and I noticed the multimeter gives me a resistance of about 450 ohm when I check the red wire and - D- D+ (minus, data- and data+). Ps: when the cable is completely disconnected from the device the multimeter doesn't show me any resistance.. Now can anyone explain me something about electronics and maybe help me to find out the issue? I thank a lot everybody in advance!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Cut the end of the usb cable, approx. 5 cm and resolder it. It should work.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Fabri 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 20
전체 시간: 2,387
