주요 콘텐츠로 건너뛰기
The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
205 질문 전체 보기
I got Coke in my 2ds. How do I fix it?
I had it in a bag and Coke got all inside the DS. The light will come on, but, nothing will show up. How should I fix it if we don’t have the alcohol for it? Also, will GameStop refix it if I say it was an accident and I really did try to take care of it.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Tʜᴇ Pᴀᴄɪғɪꜱᴛ • Wɪʟʟɪᴀᴍ Vᴀʟᴀᴅᴇᴢ  if by Coke you mean the soda, you will have to clean it and quickly. Disassemble it by using something like this guide Nintendo 2DS Motherboard Replacement Then clean every bit of it in 90%+ isopropyl alcohol. Use something like this guide Repairing iPhone Liquid Damage to clean it. Even so it was written for an iPhone, the cleaning process is the same. Once you have it properly cleaned, replace the battery and then re-evalaute for any further damage. The longer you wait the greater the chance of corrosion from the acid and sugars involved with your soda.
iPhone 이미지
안내서
난이도:
어려움
1 - 2 hours
Nintendo 2DS Motherboard 이미지
안내서
난이도:
운영
30 - 40 minutes
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
귀하의 답변을 추가하세요
Tʜᴇ Pᴀᴄɪғɪꜱᴛ • Wɪʟʟɪᴀᴍ Vᴀʟᴀᴅᴇᴢ 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 138
