주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
클릭형 기계식 게이밍 키보드 - 완전 프로그래밍 가능 및 5개의 매크로 키. 2010년 최초 출시.
Slow, delayed key response?
I’ve had my Blackwidow Chroma for a year or two, but only recently I noticed that, in games, the A key isn’t responding to presses in time. It can vary, from about a half-second delay on press, to a full 4 seconds, but it’s definitely there. Does anyone else have issues with this? Is this a common problem with other keyboards? How do I change out the switch if it’s compromised?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
I have the same problem but with my D key, has any fix been found for this problem
의 공유
It also happens to me but in the R key and the V key, I have cleaned it up but it stills the same I really dont know why it may be the USB port
의 공유
댓글 달기
답변 5개
가장 유용한 답변
Can you pull keys off? Try pulling it off and see if typing with it off works well. You can also pull another key off from a key you don’t use and put it on the A key spot, doesn’t matter. Then try pressing on it and see if it works.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Just turn off the LEDs.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
It works if you turn of the LED’S as Filipi said. But the problem is the key that was lagging had been assigned as a macro key. Reset that to default and you are good to go. I dont know why this happend or how.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I have used static color and it seems to have fixed the problem. I’m not sure how this keyboard is built, but I suppose it’s the keyboard’s controller that has this issue…
이 답변이 도움이 되었나요?
점수 0
댓글 달기
recently my RAZER Macro keys of Blackwidow (M1~M5 keys) input speed slow down.
(kind window slow problem - they input funtion of M1~M5keys and there are deep delays - keep Ctrl hold kind...)
but i got a hint from these answers.
so i just turn off and back on about CHROMA color fucntion. it's fine now.
thank you guys.
이미지
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Daniel Nicolson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 13
지난 30일: 53
전체 시간: 12,647
