주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GoPro Hero5 Black는 2016년 10월 GoPro에서 출시한 HD 방수 액션 카메라입니다. 4k 해상도의 이 비디오 카메라는 음성 제어, 터치 스크린 디스플레이, 내장 와이파이 기능을 갖추고 있습니다.
LCD Screen not working
Good Day,
My GoPro hero 5 is working but not the screen, the screen has no power but it still response when you tap the screen
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 6
댓글 5개
Me too. my camera's screen just stopped working and GoPro told me to send the receipt and I would get a new camera, but when I sent the receipt a different GoPro person told me I would only get 20 per cent off a new camera. I read that they were replacing all cameras with this default because it was a defect. Has anyone else experienced different messages from GoPro like this?
의 공유
Yes, I have experienced the same problem
의 공유
Yes I have the same problem with mine.
의 공유
There's a cable between the battery and micro sd card slot and that cable you have probabbly cut or something while accedantly putting the sd in the wrong place.
의 공유
LCD is not working of my GoPro black5
의 공유
댓글 달기
답변 2개
선택된 해법
Hi,
I assume that you cannot view the menus on the screen either
It may be either a loose connection to the LCD screen, that the LCD screen is faulty and needs to be replaced or worst case that there is a fault on the motherboard.
Try shining a torch at an angle close to the LCD screen to check if you can detect an image at all when using the camera. It will be very faint so try it in a darkened room if possible.
If you can detect an image it means that there is a backlight problem with the screen. Either there is no power being supplied from the motherboard to the backlight circuit in the LCD screen or the backlight circuit in the screen is faulty and the screen will have to be replaced as it cannot be repaired. Hopefully it is not a motherboard problem in supplying backlight power to the screen.
If you cannot detect an image (or even if you can) then unfortunately without a schematic, the only way to determine if it is a problem with the screen or the motherboard is to replace one or the other. Again hopefully it is not a motherboard problem.
Here’s a link to a video that shows how to replace the LCD screen + digitizer in the camera. This will also help you to check if the LCD video flex cable connection is OK.
Here’s a link to the GoPro Hero5 Black guides which may also help if the video isn’t clear enough at some points. Unfortunately there is no ifixit guide showing the LCD screen removal.
Here’s a link to a replacement GoPro Hero5 Black Rear LCD and Digitizer part from ifixit.
Here’s a link to a replacement GoPro Hero5 Black Motherboard part from ifixit just to give a comparison of the cost difference between the two parts.
You may find the parts cheaper elsewhere. Just search online.
Hopefully this is of some help.
This part is the motherboard for the GoPro Hero5 Black action camera. 이미지
제품
$24.99
Replace a rear LCD display and touch screen compatible with a Black Edition GoPro Hero5 camera. Includes the Rear Glass Digitizer Panel and Flex Cables. 이미지
제품
$69.99
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
So my camera's screen just stopped working and GoPro told me to send the receipt and I would get a new camera, but when I sent the receipt a different GoPro person told me I would only get 20 per cent off a new camera. I read that they were replacing all cameras with this default because it was a defect. Has anyone else experienced different messages from GoPro like this?
의 공유
The LCD screen is "lit up" for me but no image would this be a ribbon cable or something worse?
의 공유
@basicquestion
Take some pictures with the camera and then check if they're OK when downloading them from the SD card plugged into a card reader connected to a computer.
If the images are OK then it could be faulty LCD screen, a LCD screen cable/cable connection problem i.e. loose video cable, backlight power cable OK or a problem with the motherboard - LCD screen video circuit.
If the images are black then it's the motherboard.
I realize that you cannot "see" what pictures you are taking but the camera may still be mostly working OK if the downloaded pictures are OK
의 공유
댓글 달기
I fix mine take apart clean put back together it works
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
mr_gemini_31 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 7
지난 7일: 21
지난 30일: 96
전체 시간: 37,239
