주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2015년 중반 Acer에서 출시한 보급형 중급 노트북입니다. 이 노트북에는 Nvidia 940m 그래픽 카드, Intel i5-5200U CPU, 1080p 디스플레이가 탑재되어 있습니다.
Broken Hinge on laptop
Hey, my laptop Acer Aspire E 15 (E5-575G) has a broken right hinge. Due to this the right hand side of the screen has separated from the keyboard. This issue is starting to create an issue in the left hinge as well as it is slowly becoming damaged aswell due to the opening and closing of the lid. If you believe you can help can you please contact me on thealexmartins@gmail.com. I am able to send pictures for further explanation.hing
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Hi @thealexmartins ,
Here’s a link to a video that shows how to replace the hinge assemblies.
Replacement hinge assemblies are available online. Just search for Acer Aspire E 15 (E5-575G) hinge parts to get results for suppliers of the part.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Unfortunately it's more often the plastic that the hinges screw into that fails rather than the hinges themselves. You may be able to glue it back together with epoxy (2-part) rapid glue but you will need to add reinforcement, such as by building up the glue around the crack and/or gluing a piece of fibreglass matrix board or a piece of an old de-populated printed circuit board over the crack on the outside of the case.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Drill holes through the lid where the original screw sockets have pulled out and reattach the hinge with screws, nut and lock washer through hinge and lid. a bit inelegant but effective and a lot cheaper than the $90 for a new lid,
의
댓글 달기
답변을 추가하세요
Alex Martins 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 29
전체 시간: 7,676
