주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
TI-Nspire CX 핸드헬드는 풀컬러 백라이트 화면과 얇고 세련된 디자인을 갖추고 있으며, TI-Nspire 충전용 배터리가 포함되어 있습니다.
Nothing showing on the screen?
Hi! I have a TI-Nspire CX calculator, and now my calculator can’t turn on the screen. It’s broken maybe is because I am trying to upgrade the calculator to a TI-Nspire CX  CAS calculator.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 5개
You cannot simply flash the CX CAS firmware to the CX calculator so you may have bricked the calculator. If you haven't already tried: unscrew the battery cover and remove the battery; while the battery is the removed press and hold the reset button down (using a pen, paperclip, etc.) for around 10 seconds. Put the battery back in and let us know if it works!
의
Honestly I'm not much help with Nspire calculators. @a16457m I suggest you turn your comment into an answer!
의
Will do @TheLastMillennial
의
Lol I flashed my nspire with the cas os
의
댓글 달기
답변 2개
가장 유용한 답변
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I was having trouble with a CX nspire. The startup sequence would run and then the calculator would go into a dark grey screen that seemed to have moving lines. I reset several times, no success.
What fixed it was the following. I switched out a battery from a good calculator. With the good battery, the computer was able to restart and run normally. When I put the old battery back in, the calculator also ran normally. (while connected to power on the usb cable)
I am going to let in charge for a while and see if the fix is permanent. I may have to buy a new battery but at least it is working now.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Wenqian Li 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 19
전체 시간: 2,621
