주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG X Power는 2016년 8월에 출시된 4G LTE 스마트폰입니다. 이 모델은 16GB 메모리를 탑재하고 있으며 안드로이드 운영 체제(OS)로 구동됩니다.
phone is very hot
I have a lg-x230yk
1 month old it does not stay charged and gets very hot
I only have emails and face book apps
wifi and blue tooth is off
im new to phones
thanks julie
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Depending on carrier usually in Sprint zone or my Verizon there is a support section which you can run a diagnostics on the battery life/usage. That will show what is using the most battery charge.
Now for the phone getting warm. LG’s (I’ve had the G5, X, and now the G7) all of them have had a horrible issue with heat dissipation.
some things to take into account, do you have mobile data enabled? If the phone is constantly switching between 4G/3G/1X then this would account for the heat & battery drain. or are you possibly in a weak cellular signal area? If it's constantly trying to find a signal then the same thing could happen.
A way to test (which can be a nuisance since we usually need our phone) is charge it up and place it into airplane mode. If it continues to overheat and drain battery there. If the issue goes away then it is definitely one of the issues with data/signal. If not I would look at replacing battery. As for the heat… there may be a couple applications that assist in identify battery life issues but I hope we don’t have to get to that point.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
julieblue2011 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 385
