주요 콘텐츠로 건너뛰기
6s와 유사한 하드웨어 사양의 4-inch iPhone은 2016년 3월에 출시되었습니다. 16/64GB 저장 옵션 및 은색, 스페이스 그레이, 금색 또는 로즈 골드로 제공됩니다. 모델 A1662 및 A1723.
1049 질문 전체 보기
iPhone SE GPS module or hardware pictures
Hi, I have a problem with my iPhone SE GPS, who can help me to see the iPhone SE GPS hardware( antenna or module) in the pictures? I visited so many sites and could not see it. Are the WiFi , Bluetooth and GPS antenna the same?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Almost exactly the same with iPhone 5s.
The GPS processor is the cellular chips themselves. They are located at the lower half of the board.
There is an RF bridge cable running across the board to the top, where the antenna is.
On the upper half of the board, there are multiplexers, LNAs, filters, etc. RF stuff.
The antenna feed point is at the very top of the board, bottom side, next to a screw hole. GPS and cellular signal shares the same antenna, the top bezel itself.
There is a screw and a metal clip connecting the antenna feed point to the top bezel. Forgetting one of them may resulting poor cellular reception, slow cellular download and no GPS.
해당 답변은 도움이 되었습니까?
점수 4
댓글 5개:
thanks , i got it, bout another question, What do you mean about the metal plate? is that below picture ?
http://uupload.ir/files/z1kp_kslskxjccwp...
Yeah that one.
Is there a video/picture of where and in which direction to place this metal plate?
Any update on this, im also have gps problem.. where need the metal need to located?
The plate is fixed using the 2.4 mm Phillips #000 screw at the top of the logic board (iPhone SE Logic Board Replacement). From the top the screw goes through
1. the hole attached to the case,
2. the logic board,
3. the metal plate
It is the same as in the iPhone 5s (아이폰 5s 로직 보드 교체).
댓글 달기
귀하의 답변을 추가하세요
mozafar 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 19
전체 시간: 1,970
