주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Google의 2세대 Pixel XL은 모서리가 둥근 6인치 P-OLED 디스플레이를 자랑합니다. 64GB 및 128GB 스토리지 구성과 두 가지 색상으로 제공됩니다: 저스트 블랙과 블랙 앤 화이트. 2017년 10월 19일 출시되었습니다.
Is my screen fixable?
Hello,
I recently smashed my phone on concrete when I slipped while running. The top left corner of my Pixel took the most damage.
이미지
이미지
Is my phone repairable? I’m assuming I’ll need to get a front camera replacement and a full screen + digitizer. I can’t tell if the frame is damaged beyond repair… Any advice/comments would be appreciated!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
if price is a concern and the phone still functions..looks like it's just the glass over the camera and may not involve the actual camera at all/touchscreen functions intact, you could just apply sticky tape/contact adhesive to prevent further damage etc and keep on using the phone. you may have a few pieces of glass over the camera which may show up on photos, but seeing as this is the selfie camera, if you don't use it what does it matter?
의 공유
댓글 달기
답변 1개
가장 유용한 답변
Hi,
This link may be of some help.
They should give you a quote for the repair if nothing else.
Update (11/06/2018)
Here’s a link to the ifixit Google Pixel 2 XL 스크린 교체 guide.
Once you have removed the old screen you should be able to determine what else, if anything, needs to be replaced. It may depend on how well the new screen sits back in.
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
I appreciate the link, but it doesn't answer my question. I'm trying to decide whether or not ifixit tools will suffice in repairing my Pixel device.
의 공유
The answer is yes. You should change the screen completely. Your screen has part of the LCD broken, so it is not possible to repair. You can change the glass, but the spot on the LCD has no repair.
The camera should try it to know if it should change or not, if it looks good I would change it. Due to the opening problem, you must first remove the screen to access the rest of the terminal, I advise you to be sure before sticking the screen to the chassis.
If the frame is damaged, it can be repaired with a sandpaper and patience. But it will not be like new.
의 공유
You will need additional stickers that may not come with the screen. Luck!
의 공유
댓글 달기
답변을 추가하세요
Timothy Lee 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 27
전체 시간: 2,023
