주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2016년 1월에 출시되었으며, 모델 번호 BDP-S3700으로 식별 가능함
Why does the open/close button not work
I have disconnected both the audio and HDMI cable from my device.
After turning on the device, pressing the open/close button has not effect. The green power led is on.
I have tried resetting by holding on the open/close button, and the plugging in the power cord. This did not fix the problem.
Any suggestions or advice would be gratefully received.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@igreid wonder if it is in demo mode. While the player is turned on, press  ■ (stop) , RETURN, (pause), and then the SUBTITLE  button on the remote to disable it.
You can also try to open the case by inserting a paperclip in the hole of the drive
이미지
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thanks for the suggestion. This did not help.
This is the second unit I have had this issue with
Not sure what to do next.
의 공유
댓글 달기
답변을 추가하세요
Ian Reid 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 9
지난 30일: 19
전체 시간: 460
