주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ematic 태블릿을 위한 수리 안내서 및 지원.
Only works when plugged in
Battery says 66% but tablet only works if plugged in what’s wrong
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Seems like the battery is stuffed. Does it ever go above 66% if you leave it plugged in for a while?
의 공유
댓글 달기
답변 3개
가장 유용한 답변
Hi,
The battery may be failing to hold its’ charge and needs to be replaced. Even rechargeable batteries have a lifespan.
Here’s a link to the ifixit Ematic Tablet guides.
Hopefully your model is amongst those listed.
All of them show how to at least open the tablet so that access to the battery is possible. Most, but not all of the guides also show how to remove the battery.
Replacement batteries may possibly be available online. Just search for Ematic (insert model number) battery to get results for suppliers.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
The battery is most likely defective. Had the same problem. Return it and get ur money back if you can. I had past the 90 days for return and had to return to Ematic. It has been a year and still haven't received replacement or refund. Their customer service is horrendous, they don't do anything and don't know anything. Get your money back if you can. Thank s company is shady to say the least.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I also had the same problem with my ematic mp3 player. it would say fully charged, but wouldnt work unless it was plugged in. You might want to order a new battery, or return it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Diane roberts 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 19
전체 시간: 530
