주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2015년 9월 25일 Apple에서 출시한 iPhone 6s에 대한 수리 정보 및 안내서입니다. 모델: A1688, A1633
Unable to activate - error.
Trying to set up this iPhone 6s and I keep on getting this message.
Unable to Activate
An update is required to activate your iPhone.
I have put it into restore mode twice now into iTunes on my Mac and attempted to Update & Restore. Still coming back with the same thing. Haven’t tried just restoring but it’s saying it needs an update. Also has the small exclamation mark in the top left hand corner with a “No Service” sign next to it, even though it has a SIM in it.
Any help would be much appreciated.
— Sam :)
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 37
댓글 13개
Iphone 6
Unable to activate
Solution
의 공유
I have no clue how on earth is this website gained enough SEO To be this high up in this search there’s absolutely zero knowledge or advice on this page is absolutely useless
의 공유
If you have a question, ask. If you have a better answer you're free to contribute, anytime. Criticism is always welcome, pointless whining is useless.
의 공유
hi
i dont active my phone
after update whit itunse back again to unable to activate your phone page
의 공유
i can't activate iphone 6s after update.unable to activate an update is recuired to active.please help me
의 공유
댓글 8개 더보기
댓글 달기
답변 11개
가장 유용한 답변
I think your phone not have IMEI now.... Check on Activision screen symbol “I “ ….. When you not see the IMEI is baseband problém... Without IMEI not possible
이 답변이 도움이 되었나요?
점수 12
댓글 5개:
@vojtech So, without the IMEI it's impossible to restore?
의 공유
what do you mean that there is ni imei how is it possible
의 공유
how imei not show in the iphone is it some things are missed or stolen
board
의 공유
A fault in baseband circuitry is enough to have a phone being unable to provide the associated IMEI code. Nothing to do with a stolen board.
의 공유
how solution???
의 공유
댓글 달기
Follow these steps:
  1. Check the list on the System Status page. If the box by iOS Device Activation isn't green, try to activate your iPhone later.
  2. If asked to enter your password as you activate your iPhone, enter the password. (A password prompt means that Activation Lock might be enabled in Find My iPhone.)
  3. Restart your iPhone (Skip since you have tried this method).
  4. If you're using a cellular data connection, connect to a reliable Wi-Fi network instead.
If you still can't activate, here's how to activate your iPhone through iTunes instead:
  1. Make sure that you have the latest version of iTunes.
  2. Check that your computer has an Internet connection.
  3. Open iTunes on your computer. With the cable that came with your iPhone, connect your iPhone to your computer.
  4. Wait while iTunes detects and activates your iPhone:
  5. If iTunes shows, "Set up as New" or "Restore from Backup," it means that iTunes activated your iPhone.
  6. If an error in iTunes says that the SIM card isn't compatible, contact your carrier.
If all of the methods not working, try to contact Apple Support.
이 답변이 도움이 되었나요?
점수 4
댓글 달기
iUnable to activate related to baseband issues.If the phone fails to detect IMEI while on activating the phones.There is common problem shows on.The way of repair that problem
.1- BBPMU reball
2- Wtr problem
3- BBCPU reball
That need to hardware skill that can`t be fixed with software.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Sim not valid iphone6s
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Here's a bypass to get more usability out of your device (not a complete fix)
https://youtu.be/3NSWsWeINC8
이 답변이 도움이 되었나요?
점수 1
댓글 달기
My iPhone not activated no service
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
My iPhone no service problem not activated
의 공유
댓글 달기
Why showing unable to activate
이 답변이 도움이 되었나요?
점수 1
댓글 달기
My iphone like this this for 1 week now i cant call nothing. and now i cant live.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
my iphone 6s unable to activate
이 답변이 도움이 되었나요?
점수 0
댓글 달기
my problem is that my iPhone is saying unable to activate ,You iPhone could not activated because the activation server cannot be reached
이 답변이 도움이 되었나요?
점수 0
댓글 달기
You have to jailbreak it with ramdisk and create new apple id
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Sam Mileberg 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 58
전체 시간: 35,436
