주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG G Pad X 8.0은 2016년 6월 T-Mobile 네트워크용으로 모델 번호 v521로 출시되었습니다. 이 태블릿은 8.0형이며 옥타코어 프로세서를 탑재하고 있습니다.
Broken Tablet Screen: How To Fix?
My tablet’s screen is basically half broken like fully black with some cracks here and there. I don’t want to upset my father so how should I handle this. As I already stated, half of it is glitched as in broken while the other small spaces barely work.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
how old are you?
의 공유
댓글 달기
답변 1개
선택된 해법
Hi,
You need to replace the screen assembly(i.e. LCD screen + digitzer).
Here are links to two videos that show how to replace the screen assembly in your tablet.
screen replacement Pt.1
screen replacement Pt.2
Here’s a link to just one supplier of the replacement part. It is shown just to give you an idea of the cost of the part. There are other suppliers that may suit you better. Just search for LG G pad X 8.0 v521 screen replacement part to get results for suppliers of the part.
It may be advisable to tell your father as most probably he’ll find out anyway. So ‘fess up and get it over and done with. He most probably won’t show it but he may be pleased that you told him before he found out about it, and that you have found out how to fix it. You could even suggest that you could both try and fix it together. ;-)
ifixit also sells the appropriate tools that you may need to use.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Giang Tran 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 36
전체 시간: 1,606
