주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2016년 6월에 출시된 Motorola 스마트폰으로 Moto Mods(스피커, 충전기 등)라는 추가 기능을 갖추고 있습니다. 출시 당시 Moto Z는 역대 가장 얇은 스마트폰(5.2mm)이었습니다. 모델 번호는 XT1650-01 및 XT1650-03입니다.
moto z keep restarting
hellow,
my moto z keep restarting and some time it stop for a few hours or days,
when in connected it to the charger it stop restarting when i plug out the charger it will restart after minutes or hours ?
thanks
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Hi @sharara ,
Try using the phone in safe mode and see if the problem still occurs.
If it doesn’t occur in safe mode (allow enough time to be sure) and it is operating on the battery only, then a downloaded app is the problem. The trick is to find out which one. You’ll need to uninstall each downloaded app, one by one, and run the phone in normal mode between each uninstall to see if it operates correctly. Once it does then the last downloaded app that was uninstalled is the cause.
If it still occurs in safe mode and if it only has problems when working on the battery only, then perhaps the battery is failing and needs to be replaced.
Here’s a link to the ifixit Moto Z 배터리 교체 guide, which may be of some help.
Replacement batteries are available online. Just search for Moto Z battery to get results for suppliers of the part. Ensure that it is suitable for your exact model number.
이 답변이 도움이 되었나요?
점수 3
댓글 4개:
thank you jayeff
i will do
의 공유
Hi jayeff
the restart problem is still occurs in safe mode and only stop when i put it on charging
so as you said the battery is failing and needs to be replaced?
의 공유
Hi @sharara
Yes. It seems as though the battery is the problem.
If it were another hardware fault or a software problem which was causing this to happen normally it wouldn't matter whether you are on battery power or charger power, it would still happen
의 공유
thanks alot
regards
의 공유
댓글 달기
Interestingly, coincidentally I thought this was my problem with my Moto-Z Play restarting/rebooting… in fact, it was the aftermarket case that had either aged/hardened (soft rubber extrusions to volume/power buttons) or just shrunk/tightened and it was the physical contact with the case that was restarting the phone. Simple in the end but frustrating to trouble-shoot. Thought this might help someone else with the…not so obvious.
Bill D.C.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
mohammed 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 21
전체 시간: 6,600
