주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2015년 9월에 출시된 5.5인치 ZTE 스마트폰.
How to fix storage space running?
keeps says storage space is running. How can I fix this problem?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
Hi @islands7
If you have a ZTE ZMAX 2 check if it has Android Ver.6.0 installed.
If not update the firmware to this version and then you can try to format the SD card as internal storage.
If you need more storage change the SD card to a max of 64GB to give a total of 80GB which is no more that what was possible before but now you can have apps on the SD card as well.
I did say try, because a lot depends on what options the device manufacturer will allow with the firmware that they use in the phone.
Also I'm not totally sure with your model that if the above works that when formatting the original SD card it might erase everything from the card so maybe do a backup first or use a new SD card
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Dear Thompson,
Now a days many of user experiencing the same issue.
it can be solved easily by
  1. Adding one memory card. the move some internal memory file (Phone stored personal data) to external memory.
  2. Uninstalling unwanted application
  3. Resetting your phone (Your data will lost).
Best of Luck
For any further queries you can comment here
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Did not work, no advice about moving apps to SD card when no option displayed
의
댓글 달기
답변을 추가하세요
r.s.thompson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 15
전체 시간: 437
