주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Charging Port Is Broken!
So on the bottom of any ipod (im pretty sure)there is what you would call a charging port.Thats basically where the usb cable goes. And well mine is kinda broken. Some of the little prongs(i guess you would call it)are either broken or bent. Due to that, my ipod cant be charged or updated and anything that includes the usb cable. Please help i dont know how to fix it! thanks
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 1개
I've had no functional problems with this. Everything hooked up fine. I am running Windows 8.1 and have had no issues. It works like a charm.
https://www.amazon.com/Liztek-Universal-...
댓글 달기
답변 5개
선택된 해법
bella,that is the dock connector. You will have to replace it in order to get your iPod back to normal function. It is an interesting job to say the least. You have to remove the logic board and then desolder the connector. The dock connectors are available at multiple places like this Then you have to resolder the new one. here is a video that shows you how to do it. Good Luck.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Just to add to what oldturkey said, I would recommend buying a fine tip for your soldering iron (not too fine) and definitely invest in some solder flux as well as thin solder wire. Great weekend project, good luck!
댓글 달기
put the charger on the left side a bit lose and the other side normal
이 답변이 도움이 되었나요?
점수 0
댓글 달기
All you do is plug it into the charger.. Turn it off.. wait a hour or so.. should charge but you cant connect it to the computer that way, if it is dead plug it in, it will turn on automatically and then turn it off. Hope this helps x
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Get a universal charger if the port is no longer working or damaged http://hpanswers.blogspot.com/2013/07/ge...
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Read the question :"Some of the little prongs(i guess you would call it)are either broken or bent." Your idea definitely does not work. Are you even remotely aware of the multifunction for the dock connector?
댓글 달기
it want charge what do i do
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
bella 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 28
전체 시간: 29,708
