주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2017년 9월 22일에 출시된 Apple의 3세대 스마트워치로, 셀룰러 연결 기능을 선택할 수 있습니다.
Water damaged Apple Watch
I went out for a run, took my watch off because it died and I put it in my pants pocket. I washed those pants and now the screen is cracked and has water damage. It will not turn on. I’ve tried everything. Is there any possibility that my watch could be fixed and if so what would it cost? It’s a Series 3 I believe.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 3개
My Apple Watch died while I was inside the Pool and now is full of water inside how would I fix this ?
의
Hi my Apple Watch died too but I washed my hands my screen was already cracked and it stopped there got soap and water on the display and if I’m super unlucky it will be in the battery or logic board too I want to repair it by myself but idk what is broken or what to do someone I need advise and some thoughts if it’s riviveable
의
Same thing happen to my Apple Watch. Did you have to replace everything or just a few different parts?
의
댓글 달기
답변 2개
가장 유용한 답변
If you believe it has water damage, you must disassemble and clean it using at least 91% isopropyl alcohol, (you can use this Apple Watch Series 3 분해도 to do that) make sure to scrub everything with a toothbrush.
more details on water damage can be found here: Electronics Water Damage
It is a tough repair, but as long as you follow the instructions you should be fine.
이 답변이 도움이 되었나요?
점수 9
댓글 1개:
I went to the beach and I didn’t lock my Apple Watch and now the brightness is red and I can barely see or know where things are, hoe can I fix it?
의
댓글 달기
I was scuba diving and found a Apple Watch and I want to see if it can be fixed
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Breniecia Camphor 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 21
지난 30일: 59
전체 시간: 38,151
