주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2012년 6월 출시 / Turbo Boost를 탑재한 Core i7 프로세서 / 최대 1 GB GDDR5 비디오 RAM
Replacement battery keeps not being recognized
I ordered and installed a replacement battery from iFixit and it seemed to be working fine for a while, however after running for a while the battery will not be recognized. When this happens, if I shut down and reset the SMC it will work again for a while but will later do the same thing resulting in needing another SMC reset.
I’ve also reset the PRAM along with updating to the latest SMC firmware for my Mac model all to no avail. I’ve inspected the battery connections many times and it appears to be plugged in just fine. I figured it’s not due to a faulty connection since a SMC reset kicks it back into gear, but this issue is really messing with my workflow.
Any help is greatly appreciated!
EDIT: I’ve also downloaded and ran CoconutBattery. After a fresh SMC reset, coconut says that the battery is in good condition and has no issues.
EDIT 2: Here is a screenshot of CoconutBattery with the SMC freshly reset (battery working)
이미지
Here is after battery stops being recognized:
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 1개
install this gem of an app CoconutBattery paste a snapshot of the main window for here so we can see whats happening 기존 질문에 이미지 추가하기
의
댓글 달기
답변 5개
가장 유용한 답변
Did you contact them? I promise you they will replace it!
Contact iFixit Customer Support
이 답변이 도움이 되었나요?
점수 1
댓글 달기
For what it’s worth, I’m having the exact issue, and I’m on my second iFixit battery. The first one had this issue, so I tried unplugging and replugging in the battery connector and resetting SMC and PRAM all multiple times to no avail. I contacted customer service, and they were kind enough to send out another battery, but unfortunately, this one is having the same issue even with the troubleshooting described above. I can’t imagine a third will behave any differently. My Apple battery does not have the same issue, so I believe the problem has to be confined to these replacement batteries.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
They kindly sent me a new battery too.
But if you say true and none battery of this model works, I hope there will be a solution of refund.
의
My second new battery works perfectly, thank you all and thank you iFixit!
의
댓글 달기
Hey,
I have exactly the same problem as explained above.
Here are my screenshots of coconutBattery (before and after the battery is no longer recognized), do you think I should also contact the support?
이미지
https://i.imgur.com/8ic3V00.png
이미지
https://i.imgur.com/I2nscLd.png
Note: I have the same serial number as cknazze battery has ''too?!?
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Contact IFIXIT store for a replacement as your battery is defective. The packing slip will have the info on how.
의
Great !
I'm going to do it, I just wanted to know if the second new cknazze battery worked well?
의
댓글 달기
Hey there ill do have exect the same problem. Will contact the Support for replacement.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I’m having the same issue. Serial no is the same as cknazze. This is a coconut battery screenshot of when the MBP recognizes the battery. Can you see any obvious problems?
이미지
I’ll post another screenshot from coconut when it stops recognizing the battery again.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Hi There,
Augie from iFixit here! Although I'm sorry to learn of the issue, we'll be more than happy to help.
Was this ordered from iFixit? If so, could you please email us at support@ifixit.com with your order number (or email address used to place the order)?
From there, we'd be more than happy to help get this handled in no time.
Thanks again,
Augie
의
댓글 달기
답변을 추가하세요
cknazze 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 14
전체 시간: 907
