주요 콘텐츠로 건너뛰기
An SSD, or Solid State Drive, is a type of storage device that uses NAND-based flash memory to store data.
20 질문 전체 보기
SSD failed to restore
APFS failed to invert. OSS Error 22
Update (02/14/2019)
Mac mini (Late 2014) running Mojave (10.14.3).
I was able to clone the drive with the Carbon Copy Clone app. I'll know today if it was successful after I install it.
Thanks Jonah
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
What is the exact Mac system you are using as well as the drives specs.
댓글 달기
답변 2개
선택된 해법
Success! The SSD is up and running.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
가장 유용한 답변
Disk Utility no longer works with APFS file systems for restoring/cloning devices. Using a Time Machine backup or Target Disk Mode on an old computer are the only ways to transfer data.
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
Don't know why you're talking about Disk Utility here as we still have no idea what the system is. Until we get that you're just shooting in the dark.
FYI: The cloning options are no longer present in the latest version of Disk Utility
Are you restoring the drive with CCC or Disk Utility? I just want to double check where you’re actually seeing this error.
Error was with disk utility. CCC worked perfectly. Up and running!
댓글 달기
답변을 추가하세요
Kenneth Hillman 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 551
