주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The JBL Charge 3 can be recognized by its distinct woven speaker cover and rubber accents. It was released in 2016 and features a fully waterproof design, 20 hours of playback time, and bluetooth connectivity.
The aux input sound is distorted when the cable is plugged in
hi!
When I use the aux input and plug in the cable correctly, there is a heavy “robotic” sound,
when I slightly pull the plug it seems to get the correct signal, but I’m worried it’s mono.
Does anyone recognize this?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
I have the exact same problem with my JBL Authentics 200! So annoying, brand new... Edit: It actually seems to be the connected device which for some reason doesn't output audio correctly when both channels are connected, since it works correctly with my other devices.
댓글 달기
답변 1개
선택된 해법
Hi,
If your JBL speaker produces distorted sound, see the JBL Charge 3 Sounds Distorted problem page for possible problems and solutions.
Adjust the balance on the audio source (or connect the speaker to an audio source that has this ability) so that you can tell if it is in mono or stereo when you slightly withdraw the plug from the aux socket. Try full L and then full R to listen if each speaker still works.
It may be that there is a faulty aux jack in the speaker. Unfortunately, they cannot be repaired but have to be replaced
Here’s a link to the ifixit JBL Charge 3 Motherboard Replacement guide, which may be of some help gaining access to the aux port.
I cannot find a service manual or a parts list for the speaker so you may have to search on places such as this to try and get a compatible replacement part. Look for 3.5mm phone connectors and then check the datasheets for the component to see if it matches.
Hopefully, this is of some help.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Martijn Comes 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 45
전체 시간: 7,023
