Capacitor problem, choosing capacitor
Good Day!!!
The board is vr1 version of sega game gear. I can't find a 33uf, 0.47uf, 4.7uf, 22uf, 68uf capacitor can I use higher value? Thanks in advance!!
좋은 질문입니까?
Good Day!!!
좋은 질문입니까?
Hi @faustrepair ,
You cannot use higher values than what the circuit design requires. It will change the characteristics of how the circuit operates (if it still will operate that is) if you do.
The type and values of the capacitors were selected for a reason when the circuit was designed
Did you check on places such as this?
Also you’ll have to know a bit more that just the capacitance value. Such as working voltage, what type of capacitor, physical size etc.
이 답변이 도움이 되었나요?
This is hit or miss, 1206 smd . <1uf use 1uf smd, <10uf use the 10uf, <100uf use 1210 SMD 100 uf. Few to many years later on this👍🏼
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 1
지난 30일: 21
전체 시간: 632
댓글 1개
Rumble Pirate 의
