주요 콘텐츠로 건너뛰기
Complete repair manual for the PSP Go, including battery upgrade and display repair instructions.
20 질문 전체 보기
psp go won't charge
so my Psp go isn’t working. the last time i used it was probably last year in October. I just found the charger and decided to charge it so i could play on it. I left it to charge for a good three hours, when i go see if it’s charge its not. i held the on button for a good 20 seconds and it still wont charge. Let’s see if you know any ideas to help me out
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
First, try a hard boot if you haven’t already (hold the power button for 10 seconds).
Otherwise, this will factory reset your PSP (but not delete any games saved on the memory card), but it might work for you: Try holding Square, Triangle, Start, Select, and and turn it on. Release the keys once you see the Sony logo.
If you still can’t get it booting, check the charger and maybe try another one if possible, and inspect the charging port for any damage or corrosion. If there’s no issues with the charger or port, my best guess would be a battery issue, which would require a replacement. Hope it helps!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
dontneedtoknow 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 51
전체 시간: 4,263
