주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
OptiPlex 755는 비즈니스용으로 설계된 에너지 효율적인 데스크톱 컴퓨터입니다. 2007년 중반에 출시되었습니다.
Broken Power Button on Dell 755?
power button not working on dell 755?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Power Button Not Responding on dell 755
댓글 달기
답변 1개
선택된 해법
Hi,
What colour is the Power button light showing?
Here’s a a link to the user manual for your model.
Select your particular model variant and then click on the Troubleshooting link and then on the Power Lights link and follow the procedures to find out what may be the problem.
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
No or Blank Light.
Hi,
Did you check the Troubleshooting > Power Lights guide in the manual when there is NO power button light showing?
"If the power light is off, the computer is either turned off or is not receiving power.
¡ Reseat the power cable into both the power connector on the back of the computer and the electrical outlet.
¡ If the computer is plugged into a power strip, ensure that the power strip is plugged into an electrical outlet and that the power strip is turned on.
¡ Bypass power protection devices, power strips, and power extension cables to verify that the computer turns on properly.
¡ Ensure that the electrical outlet is working by testing it with another device, such as a lamp.
¡ Ensure that the main power cable and front panel cable are securely connected to the system board (see the "System Board Components"section for your computer)."
댓글 달기
답변을 추가하세요
dasdasd asdasd 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 36
전체 시간: 2,007
