주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Scotch 모델 TL901은 최대 9인치 너비의 평평한 물체를 라미네이팅할 수 있는 열 라미네이터입니다. 두 가지 온도 설정이 포함되어 있으며, 최대 5mm 두께의 파우치를 라미네이팅할 수 있습니다.
Scotch TL902 laminator assembly instructions
I recently got the scotch laminator tl902..the sheet was jammed so,I opened the machine and removed the jam..But, now unable to assemble it back..Any step by step instructions with pictures would be great help
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
How can I close the input tray on my laminator tl902 when finished and want to put it away?
How do you get the insert tray out in the position needed to insert
laminating sheets?
댓글 달기
답변 2개
선택된 해법
Hi,
Here’s a link to the ifixit Scotch TL901 분해도 guide, which may be of some help
You may be able to reverse the procedure to re-assemble the laminator.
Research online indicates that the only differences between the TL 901 and the TL 902 is that the TL 902 is newer, lighter and has a side handle for easier carrying.
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
how do you get the back to open to put pouch in... brand new
@ann45280
You don't need to open the back.
You place the item to be laminated into the laminating pouch and then feed it through the machine.
Here's a video that shows how to use it.
댓글 달기
Here's a picture of how the TL902 roller tension spring is assembled.
이미지
Here's a picture of how the back TL902 older model roller gear is assembled.
이미지
Here's a picture of how the back TL902 newer model roller gear is assembled.
이미지
Here's a picture of how the front TL902 roller gear is assembled.
이미지
Here's a picture of where the TL902 bottom screws go.
이미지
Here's a picture of the one TL902 side screw location.
이미지
If you need pictures of anything else on the TL902, just ask. Cheers!
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I have a part that is from the other side it’s long and has a circle at the bottom can’t remember where it goes
댓글 달기
답변을 추가하세요
anusharao.p 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 13
지난 30일: 104
전체 시간: 4,910
