주요 콘텐츠로 건너뛰기
A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
1697 질문 전체 보기
Is the Optical Drive Daughterboard swappable?
Howdy. This is more of a wanting to know and if so type question. Basically I know that on PS4 the optical drive and motherboard are paired. But from my understanding, the optical drive has a daughterboard that has the chip that pairs with the motherboard. I am wanting to know if I can move the daughterboard from the old optical drive and put it on a new optical drive or does the daughterboard and motherboard have to be replaced together?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 5
댓글 달기
답변 5개
선택된 답변
As long as you have that large square chip from the original daughterboard that you can transplant onto the replacement daughterboard it will work fine. If you don't have that chip there is no way to pair the drive and the motherboard.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
PS4 CE-35888-2 Error Code fix. Don't you just have to replace the optical drive with a new one(same numbers 10 or 20) when you have the original daughter board? Asking because I'm in this situation. Really need help. Thank you!
댓글 달기
가장 유용한 답변
@car34 check with our friend @tronicsfix on here t “You CAN replace your optical drive! The trick is that you need to find an optical drive that originally had a daughter board with the same number (010 or 020) as the one you have. After you get it all you have to do is remove the board that came with the replacement drive and install the one that came off of the bad optical drive that you are replacing onto the replacement blu ray drive.” Nobody knows more about consoles than this guru!
해당 답변은 도움이 되었습니까?
점수 5
댓글 1개:
@car34 read this again :"need to find an optical drive that originally had a daughter board with the same number (010 or 020)"
댓글 달기
The drive pairing can be retained by swapping the board, but the laser pickup calibration will be off and there is basically no way to recalibrate.
For most drives this shouldn’t be a big issue, the controller chip has some sort of self adapt range, but don’t expect the drive to perform as good as new.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
I have Never ever seen an optical drive with a non removable PCB :)
however you will need to make sure the drive assembly and optical pickup are the same as the one for your consoles PCB
해당 답변은 도움이 되었습니까?
점수 0
댓글 4개:
It just I never done one and I wasn't sure how integrated it was. I couldn't find anywhere that would just say that they can be swapped. Only that the motherboard and daughterboard had to be replaced or having to marry the old chip on the new board.
yeah the drive keys need to match but you can remove the paired PCB onto your new drive assembly. Sony use multiple drive assemblies and pickups depending on the revision of console the type of assembly and optical pickup should be printed on the parts
Does this hold true for Xbox ones as well?
@tyaczikx yes you need to swap the logic /daughter board. Think there's 2 or 3 ribbon cables. And two wires to unsolder. Red and black. Solder points are labelled r and b, So its easy if you know how. I've done it twice. First time was a reconditioned one second was brand new
댓글 달기
Thanks, i replaced the PCB from my old ps4 which i also got the optical drive from, and it works now!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Carlos Ramirez 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 34
30일 전: 129
전체 시간: 13,555
