주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
점프 드라이브, USB 스틱 또는 썸 드라이브라고도 알려진 USB 플래시 드라이브에 대한 수리 안내서 및 지원입니다.
Why is my USB device not recognized?
The system of my computer is Windows 10. When I plugged in my USB hard drive it just doesn’t turn out and shows that "USB device not recognized". I have upgraded all the drivers. They are up to date but still not working. What can I do with it?
이미지
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 3개
선택된 해법
Hi, can you check the USB device from the Disk Management?
Way to check with these steps:
  1. Press Win Logo key + R and then type: Diskmgmt.msc
  2. Find your USB device there.
Give me the feedback, thanks.
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
I have followed the suggestion and the device can be found already. Thanks a lot!
Hi, if you can find the USB device there in Disk Management, that means the device is still working but corrupted due to some technical reasons. To fix this error, you can try to retrieve the data first from the USB device and then follow the steps with this link to fix: https://www.r-datarecovery.com/usb-devic..., leave me the feedback here, thanks.
I've fixed the problem with your suggestion. The software is so convenient to use. Thanks a lot!
댓글 달기
Try shutting down Windows from the Start Menu.
When shut down unplug the computer for about 5 minutes.
Plug back in and turn on.
Now try plugging in the USB device and see if it is recognised.
Let me know if it works.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thank u for your advice but the problem still remains :(
댓글 달기
Hi @jityvub
Had you tried on another computer and another USB port?
You mentioned it is a USB hard drive. Do you have model no of it?
When you connect the drive to your computer, I presume it is a mechanical HDD, do you hear any weird sounds coming out from the hard drive? e.g. some tick tick or motor spin and stop abruptly?
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
It is just a common USB flash disk.I've changed the other USB port and I can find the weird sounds but the error remains. I only have one computer can be used at this stage.
no matter what... if data is important, if it can still be access, copy it out.
댓글 달기
답변을 추가하세요
lozemyti 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 20
전체 시간: 2,562
