주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2006년에 처음 출시된 NeatDesk는 자동 문서 공급기(ADF)와 양면 스캔 기능을 갖춘 데스크톱 문서 스캐너입니다. 초기 릴리스 버전의 모델 번호는 "ADF-070108"이며, 신형 버전은 "ND-1000"입니다.
Scanner just went out
My neat scanner just went dead. Unplugged and plugged it in again; even plugged it into another outlet. Is there a reset button? Can it be fixed or is it not worth it? We had a power outage and when the power came back on it wouldn’t work. Could a power surge have burned out the power source in the scanner?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi,
If possible, it is always worthwhile to at least attempt to repair anything.
Not only is there the satisfaction of having done so, if successful, it means that in this case for a while at least it won’t add to the ever growing mountains of e-waste.
The resultant power surge that may have occurred when the power was reconnected after the outage could have burnt out components in the scanner,
Here’s a link to the ifixit NeatDesk™ 데스크탑 스캐너 회로 기판 수리 guide. This should be of some help in opening the scanner to initially do a visual inspection to see if there is any obvious electrical damage to the electronic components, such as burnt out surge suppressors, blown capacitors and blown fuses etc.
If you do see something (or even if you don’t) and are unsure, take some close up pictures of the circuit board and post them back here.
Here’s how to do this.
기존 질문에 이미지 추가하기
iFixit 이미지
안내서
기존 질문에 이미지 추가하기
난이도:
매우 쉬움
2 - 5 minutes
NeatDesk™ Desktop Scanner 이미지
안내서
난이도:
조정
1 hour
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Eileen Halverson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 14
전체 시간: 559
