주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Inspiron 1440은 2010년에 출시된 노트북입니다. 웹캠과 Windows 7이 탑재되어 있습니다. 모델 번호: PP42L
8 beeps black screen
Laptop beeps 8 times and has black screen. Will not turn on
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
The 8 beeps and Black screen means your screen isn't working
의 공유
댓글 달기
답변 2개
선택된 해법
Hi @jeanna7 ,
Is your laptop a Dell Vostro 1440 by any chance?
If so, then an 8 beep code is a display panel failure or a LVDS cable (display cable) failure.
It may be that the 8 beep code means the same if your laptop is a Dell Inspiron 1440 as they are comparable laptops.
Here’s a link to the Vostro 1440 service manual. Scroll to p.53 to view the necessary pre-requisite steps and then the procedure to remove the display assembly. This will allow you to inspect the LVDS cable and its’ connection to the motherboard and screen as well as removing the display if it is the problem.
Here’s a link to the Inspiron 1440 service manual. Click on the Display link in the contents page to go to the removal procedure for the display.
If it is the LVDS cable or the screen that is the problem, search online for the part appropriate to your particular model. With the display panels (and perhaps the LVDS cable) the part number is usually printed on it somewhere so that you can verify that you are getting the correct part.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Please refer to this site material to find your beep code
https://www.computerhope.com/beep.htm
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jean Mat 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 26
전체 시간: 889
