주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xiaomi의 Redmi Note 라인 스마트폰.
Redmi note 4 charging issue :
1.It is not continuously charging …….after 5 min or in few min it will automatically charging stopped….after i re plugged its charging ..and again same issue.
one day its charging up to 3%. fullday it connected battery indication is glowing but at the end same 3%
what is the issue any suggestion vradhakrishnan25@gmail.com
please help me
i tried many things:
1. I replaced new battery….
2. mobile factory reset by “mi pc suite mode”
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 1개
선택된 해법
Try to resolder the USB port pins.
If you have a multimeter it is more easy to locate the problem. If you have one let me know and i will tell you where to start.
이 답변이 도움이 되었나요?
점수 9
댓글 7개:
Thank you bro .....the mobile power port pin is sometime shacking......i think it is broken..
thanks for the suggestion....
의 공유
i'm glad it helped you
의 공유
yes bro the issue is fixed as your suggestion .....i given to service center again ..they replaced the mobile power port pin now its working fine .......thank u bro........
의 공유
Redmi 4 charging problem solve https://androidji.com/redmi-note-4-charg...
의 공유
Thanks for the blog! here you will also find many useful blogs https://www.bpwltd.com/hangover-tamil-du...
의 공유
댓글 2개 더보기
댓글 달기
답변을 추가하세요
Radhakrishnan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 44
전체 시간: 10,988
