주요 콘텐츠로 건너뛰기
Flagship smartphone from Huawei released April 2018. Model CLT-L29.
56 질문 전체 보기
Where is the GPS chip/antenna located
Hi Guys,
Need your expert here. My GPS suddenly doesnt seem to be working. I have tested using Hi Care app and it says that the GPS module is working. I have a hunch that there connection (antennas) might be loose. Can you guys point out where can i zoom into so that i can repair it easily? I think there is no proper contact between the antennas and the GPS module.
Thanks guys in advance. Appreciate your help.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
This smartphone has a built in GPS receiver, which is in the mainboard, which is everything in line with the cameras/flash and higher.
You can check out the entire teardown from iFixit by Tobias Isakeit here below!
Huawei P20 Pro Teardown
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Hello Albert is it possible to mark the GPS Chip for me? Thank you
@ahmet kara Hi Ahmet, my pleasure. Just check out the image, thank you~!
https://imgur.com/oPc7BvH
댓글 달기
귀하의 답변을 추가하세요
Kalpesh Shah 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 30
전체 시간: 3,334
