주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Windows XP는 Microsoft의 Windows NT 운영 체제의 주요 릴리스입니다. 이 운영 체제는 전문가용 Windows 2000과 가정용 Windows Me의 직접적인 후속 버전입니다. 2001년 8월 24일에 제조용으로 출시되었으며, 이후 2001년 10월 25일에 일반 판매용으로 출시되었습니다.
older multiuser dos question
I have an older medical system that uses multiuser dos 7 gold. The HDD is going bad so I’m cloning it to another HDD but upon booting it comes up with ibmbio.ldr missing or bad. From the reading I’ve done you can’t clone this system because the ibmbio.ldr and other system files are location specific on the drive. Is there not some program I can run like rebuildbcd within that multiuser dos environment so that it updates the mbr to its location and therefore fixes the boot stup?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
선택된 해법
Do a “sector by sector” copy which is slow but makes a perfect duplicate.
Acronis True Image backup has this setting in “Creation Mode” If I rememberr correctly.
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
I use acronis a lot and always do a sector by sector, the problem is using that novell/ibm version of dos, you have files called loader.sys, loader.com, and ibmbio.ldr that when they’re installed they make an entry into the mbr as to their exact location on the disk and if you boot and and the sequence don’t find those files in that exact location then it won’t boot, just says the files are missing or bad. so the cloning is not a problem but when those files are copied to a bigger different drive, then they’re not at the exact location specified, as sector, cylinder and track.
의
O.K. so you understand "sector by sector".
I guess this was a copy protection method.
Another solution, and this is just delaying the inevitable, is using Steve Gibson's "Spinrite" to some what revive the old HDD. If there is lots of room on the disk this could last even longer if it is just the drives magnetic medium that is the problem.
A very knowledgable techie could rewrite the mbr to match the locations of loader.sys, etc. Don't know of a program that would automatically do this. But I wish you luck.
Many years ago I remember using a debugging program that let you step through each step of the process.
의
I was hoping an old coder here may remember how to modify the mbr to do just that. Thanks
의
댓글 달기
답변을 추가하세요
Darryl Sledge 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 23
전체 시간: 783
