주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Renault Clio 자동차의 2세대 모델입니다. 1998년에 출시되었습니다.
Clio 1.2 Engine crackling sound
Hello guys! I bought a 2001 clio 1.2 16v last week, and since then i've been noticing 3 problems. I need to change a cv axle, and the valve cover gasket that is leaking to the heatshield burning oil, And there's the weird noise. It's like a crackling sound, it comes from the left side of the engine and its getting worse (when i got it, it started at about 1,5k rpm the noise, and noise at 1k) and im afraid that it's just not a annoying sound, but something serious. Here's the videos of the sound:
https://www.youtube.com/watch?v=utA6maUS...
https://www.youtube.com/watch?v=A1w8Zx2J...
Any help would be apprecitated!
Thanks!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
Hello, yes! the noise increase with the rpms. I always thought that might be a idler bearing but i don't know how to check. Can you advise?
I have 1.5 ltr engine renault and Mahindra. Sedan
It giving ticking sound
댓글 달기
답변 3개
가장 유용한 답변
@jonnhylemon 2nd video almost sounds like a bad bearing. Have you checked the idler pulley for your belts and /or if the noise comes from your AC compressor/clutch? Does the noise increase with increased RPM's?
Update (05/19/2019)
The idler pulley etc. will depend on what accessories your Clio has. Take a look at the belt diagram and see which one is for your engine. Looks like we can eliminate the 1st one. T+ is the idler/tensioner pulley.
이미지
Update (05/19/2019)
from what i can see on the video this image would be for your model. see the tensioner at the end of the arrow
이미지
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
That's very very helpful! How can i check if its the tensioner? I need to remove the belt right?
@jonnhylemon yes that would be the way to go. With the belt off you could spin the pulley and see if it makes a noise. sometimes you can also feel axial paly in the pulley as you move it. If so you know it needs to be replaced. You cal also try something a little less scientific. With the engine off spray some wd4o or equivalent right on the idler pulley than start you engoine and listen. If it changes the noise you have it pretty much narrowed down. Also, do the same with the AC and power steering pump etc. (one after the other) it'll help to narrow it down. I always worry about using a stethoscope on a transverse mounted engine since there never seems to be enough room to get to while the engine is running.
댓글 달기
I have a Renault Clio model 2007. For several days, I feel that its acceleration and speed have decreased, what is the reason, thank you.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My car crank but don't want to start
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
@neleonfourie what have you checked? Do you have spark? Do you have fuel? What year make and exact model/engine is your car?
@neleonfourie, t'as vérifié quoi ? T'as des étincelles ? T'as du carburant ? C'est quoi l'année, la marque et le modèle/moteur exact de ta voiture ?
댓글 달기
답변을 추가하세요
jonnhylemon 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 24
지난 30일: 108
전체 시간: 4,427
