주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Garmin Nuvi 200은 Garmin의 200 시리즈 GPS 내비게이터 중 하나입니다. 2007년 5월에 출시되었습니다. 미국 본토 전역, 하와이, 푸에르토리코의 지도가 미리 로드되어 제공됩니다. 클래식 실버 또는 핑크 색상으로 이용할 수 있습니다.
Disabling usb mass storage mode
Recently I plug my USB cable into my computer and now I cannot get USB mass storage mode off my garmin nuvi 200w
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 달기
답변 2개
선택된 해법
The information provided is from here and explains why it does that. "Garmin Mass Storage Mode devices no longer communicate with a computer with the Garmin Protocol but instead present themselves as a USB mass storage device. When a USB cable is connected between a Garmin Mass Storage Mode GPS device and a computer, the GPS device enters mass storage mode." so you could try the reboot by :
1) Disconnecting the nuvi from the charging cable.
2) Press and hold the battery meter icon for 8 seconds. This puts the nuvi into "system test" mode.
3) Plug in the power cable.
4) Click "Exit." The nuvi should now reboot, but remain in GPS mode!
The only other thing I can think of is that you might require a new cable, if this just came up. Good Luck and I hope this information helps.
이 답변이 도움이 되었나요?
점수 20
댓글 15개:
Thank you much for this fix!!!! It worked!!
Kathleen Marie
의 공유
you are very welcome ;-)
의 공유
Thank you, oldturkey03. Save me $$$.
의 공유
@Mark Koh, you are welcome.
의 공유
worked by pressing and holding it for a few seconds- thank you
의 공유
댓글 10개 더보기
댓글 달기
I have Garmin Nuvi 260w GPS and Have a similar problem I did and fallow all the direction from Steps 1 to 4 as stated above ,GPS started showing running Visual Maps directions ONLY . Great. better than nothing ?
But found Talking Direction is stop working , GPS DONT want to Speech ? . I checked GPS Volume, Sound Settings, i.e. sound is Abled or Disabled, it is abled and also Couple of time switching either way but GPS Don't Give Voice Direction. It Works and Gives Both Sound/Visual Directions together at the same time before performing Fix steps 1 to 4. That means when working all alone on GPS battery and not connected to Car at all> Please advice if you good guys have any solution ?. Abee
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Thank you so much. Was ready to throw in the garbage and never buy a garmin again.
의 공유
댓글 달기
답변을 추가하세요
mona 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 36
전체 시간: 41,832
